Ghost$nipa
- Jul 27, 2004
What the HELL do I buy? I am a noob and tired of researching all the crap when it comes to computers. I just want a video card that can play Far Cry at max settings. My new hardware:
Intel Pentium D 820
Intel 945P SN
Sata2 Raid 0/1
2 Gig DDr2 667mhz
550 watts PSU
XP pro
How ever I do want to know the difference of 128 bit memory and 256 bit memory speeds...whatever the heck that means. My guts tells me higher memory speeds would results better performance. Here is my problem...I see a 6800 with 256 bit speed comparied to a 7600 with 128 bit speed.....would the 6800 perform better? If so then I should pick up the 6800 with DDr3 256MB 256 memory speed? Right? Or I am so confused that I would rather pull my teeth out.....can some one clarify this crap? Seriously? My budget is would be happy with a $100 video card....but hey I can shell an extra $50 if needed for a 7600???
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1828833&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1931188&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2069688&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2156263&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1911353&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2207285&CatId=0
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1945413&CatId=0
Intel Pentium D 820
Intel 945P SN
Sata2 Raid 0/1
2 Gig DDr2 667mhz
550 watts PSU
XP pro
