Techx said:I'm looking to upgrade to a pcie mobo and want a pcie tv tuner, anyone know if they are available and which you recommend? Haven't seen any pcie AIW's yet.
thx
isnt the new creative sound card suppost to be out in march using pci-e x1Dillusion said:nothing that uses a PCI-E x1 x4 or x2 slot will be out until well into Q2 or Q3
thx
Teerex20 said:You can always use a usb tv card.i have a Ati usb wonder 2 and it's great pluse i can move it from puter to puter.![]()
I have yet to find anyone who owned a usb tv card have a complaint.They don't make a difference what system your running as long as you have usb 2.0.You also don't have to Find" the right slot and associated potential problems pci cards have.They're portable,plug and play.I'm happy with mine,i was just trying to suggest a alternative option for you.USB? heh wouldn't even a standard PCI tv card be better than a usb one?
