Hi, I have a Asrock motherboard with a e6240(266mhz fsb). My question is about the PCI-e sync with CPU option in the BIOS. If it's set to sync with the CPU what speed will the PCI-e bus run at if the FSB of the CPU is 266mhz? Will it default to 100mhz? I read that the PCI-e bus will run at half the CPU FSB which would mean 133mhz but I don't think this is correct. I think if the stock FSB of the CPU is 266mhz the PCI-e bus will remain at 100mhz in sync mode. If I go above that the PCI-e mhz will rise. Any clarification would be great.
I'm not overclocking anything.
Thanks.
Thanks.
