PCI-E slots how much power they use?
davidm71
Just wondering how much power does a typical pci-e slot drain when a high performance video card is plugged in? Is it all on the 12V, 5V or 3.3V?
The reason is that I never really could figure out why my system would shut off suddenly when playing Crysis. I have a total of 72Amps on the 12V single rail which I tested with a volt meter and was strong without deviation. Today it occured to me that maybe its probably not the 12V rail but the other rails such as the 5V or 3.3V that are to blame.
So I was wondering how many amps are pulled directly from the pci-e slots?
Thanks.
The slots dont drain any power.
3V and 5V are hardly used in a modern PC so while it possible there could be a problem, its highly unlikely.
Your system is unlikely to overload the power supplied through PCI-E as the gfx card has its own power connectors.
If they arent connected the gfx card will warn you.
Your system shutting off suddenly could be your PSU turning off due to a fault or excess current flow.
It could also be the motherboard turning off the PC due to a different fault condition.
Or an unstable overclock.
Try another PSU in case yours has developed a fault.
Try lower clocks to see if it helps (even if you arent overclocked).
Try blowing a housefan at the PC while it is open to see if there is a heat problem.
I know the PCI-Express 1.0/1.0a slots provide up to 75 watts of power. However many mid-range graphics cards border on that or go just over it and therefore require supplemental power connectors in order to power them.
