PCI-E / S939 Upgrade question...
malistrais
Greetings all.
Just signed up, but I've lurked off and on over the past few years. I'm currently facing an upgrade dilemna, and hoped I could get some opinions.
My Rig:
A64 2800+
Abit KV8-Max3
2 x 512 DDR400 Mushkin Green
ATI Radeon 9700tx (flashed to Pro bios)
The system runs all my current games fine, but the 9700 is beginning to die. I want to switch over to PCI-E (and s939, of course), but my impatience led me to pickup a BFG 6800 OC locally a few days ago. It runs great, boosting my 3dmark05 scores from about 1900 (with the 9700) to over 3800 (after I successfully unlocked the pipelines and shaders).
Now, my dilemna... It sounds like s939 and PCI-E is really the way to go, and I really want to get back on the right side of the technology curve. I spent about $325 on the 6800 (w/ tax, etc.), but can add another $100-150 to it to upgrade everything to s939/PCI-E. So... my options...
1. Stick with the 6800 OC.
2. Return the 6800 OC, sell my s754 gear, and Pick up a s939 3000+ A64, a NF4 or ATI s939/PCI-E mainboard, and a sub-$200 PCI-E 6600GT.
My primary question is performance related. Would the old 754 setup still outpace the new 939 setup (simply because of the 6800 compared to the 6600)? Or would the dual channel ram, faster HT bus, and newer tech offset that reasonably? I'm ok with the s939 setup running slighly slower if it future proofs me.
Most importantly, the Wife has already approved the extra money spent to go PCI-E. I just want to make sure it's the right way to spend the money right now. :)
Well, if you got this far, thank you. Any and all suggestions, comments, etc. welcome!
-Mal
Hey .. malistrais..
im currently in the same dilema..
i sorta just sold my old system ... which had cost myself .. quite a bit in its great day
amd athlon xp 2400+(thoroughbred)
ati 9600 pro
and some other stuff for a mere 400 bucks,.
i just bought the msi nforce 4 sli ready board... $189 @ newegg
amd 939 3000+processor $155 @ newegg
and some nice corsair ram..only 512 for now$123 @newegg .for though.. not rich
and i will add im hoping a 6800 gt card.. but settle for a 6600 gt
just wish i knew which one is best..
anyone got some reviews... i think from what i seen from my buds computer.. its a big diff. upgrading.. unfortunately i am coming from the athlon xp .. not the 754s .. dontknow if youll notice quite the diff..
good luck,...still got watercooling and hardrives to ponder..
Welcome to the forums malistrais, you probably won't notice much difference between the two platforms if you go with a 6600GT in the new rig. I would save a little more money and go with a 6800GT so that you could potentially upgrade to another one in the future. There really is no point in SLIed 6600GTs as they peform roughly the same as a single 6800GT with added heat and noise. I always recommend BFG for video card buys as I have been happy with the pair of 6800GTs I have. Other good companies include eVGA and Leadtech.
