pci-e or pci sound card?
Doesn't really matter. A lot of motherboards seem to be skimping on PCI slots, which might make PCI-E more compatible over time.
Depends on what you're after and the price you want to pay tbh. Some of the newer PCI-E cards have a lot of great features, or more great features than their older PCI counterparts, but that comes at a price, while the older PCI sound cards can have good features and cost less. I'm considering replacing my PCI X-Fi Xtreme Music for a PCI-e Auzentech X-Fi Forte 7.1 (mostly due to the headphone amp output).
I would recommend an X-Fi Xtreme Music for most on a budget, you can find them for around $40-50 if you look, I know creative was selling them at that price a few months ago. I've loved mine for the years I've owned it, it even drives my headphones quite well, but they're lower impedance so they're easier to drive in the first place. But it's definately worth it over on-board imo, I noticed a difference in sound overall, everything was clearer, the sound frequency seemed to have increased. This is comparing to my onboard on my Asus P5Q Deluxe P45 though.
It really depends on what you're after and what you expect to get out of the sound card and how much you want to pay. Hope that helps!
I would get PCIE as PCI is really on the way out. If you are going to keep the card for a while it would be a better investment in PCIE.
My new MB has only one PCI slot and I have a PCI sound card and a PCI TV tuner so I can only use one or the other. I'm keeping the sound card for now.
Thanks for the replys, I will go PCIE, I have a old PCI soundblaster, that has software that lets you record what you here so I could record a stream to wav, then covert to mp3. Does the X-Fi have that?
It has the "What you Hear" input/recording mode, at least my older PCI X-Fi does, I can only assume the newer PCI-E X-Fi's do. I think most of the revisions to the 20k2 chip is PCI-e interface and a few small bug fixes iirc. Defiantely a good choice and viable for the future though.
