pci-e for scsi controllers
z3ghz
This might be a dumb question but here goes: Can you run a SCSI controller in the other PCI-E 16x slot not occupied by a second video card? Do they even make such an animal? I have acquired 3 U320/10k drives I want to play with but don't have a controller card yet. My gaming machine blew the motherboard a few months back and my RAID 0 Raptors are resting. I'm getting by on my laptop but want to know what is the fastest slot I can use for throughput on an enthusiast class motherboard in a RAID 0? Any info is greatly appreciated, thanx!
Ouch! Hell for what they want for that one card I could build a decent budget gamer! I guess I'll use the SCSI drives for a server and go PCI-X. I've seen decent single cards for as low as $150 from Adaptec and LSI. I've never messed with SCSI drives and I've heard it can be a bit of configuring but they are 160GB/10k drives, they work, and were free. I guess I should start hunting down small workstation/server class motherboards instead eh?
Yeah, the investment in such SCSI disks may not be so attractive considering drive performances with SAS and even SATA nowadays...with that much investment, maybe you should consider SSD?
What exactly is SAS? I know it stands for SCSI Attached Serial (right?) but what are the components to use and what is the throughput? Can you employ RAID setups with SAS?
SAS disks are high-end shit, like the Seagate Cheetah 15,000 RPM drives. The physical connector is essentially the same as a SATA connector save for a plastic bit to prevent interconnectedness, and yes, they are utilized in RAID setups quite often.
I think in a few years enterprise SSD will supplant them, but we'll see...
