PCI-E Card question
Soldur
I'm looking into a new motherboard and I see that there is one socket 754 motherboard that supports SLI with 2 x PCI-E slots. Right now I'm only going to be running 1 card until I can sell some of my current parts. Can you put the single PCI-E card into either slot on the motherboard? I was thinking the top slot would be best for the most breathing room until I get another card and more fans. I didn't know if I could use it in the top slot or not?
Any help would be GREATLY appreciated!
It depends on the board, check the manual. There is usually a specific slot you have to put your card into if you only have one.
