I'm trying to find a PCI-E 1x (the short little PCI-E slot) wireless N card that can operate in the 5Ghz range (to work with a dual band router) for both my desktop and HTPC.
Only problem is, I seriously can't find one to buy!
The only Wireless N cards I can find that can operate in the 5Ghz range are normal PCI cards, which I'm trying to avoid because they would seriously inhibit the airflow from my video cards...
The nice little PCI-E 1x slots sit empty, between my video card and the CPU, and would be perfect for a wireless card if I could just find one that worked at 5Ghz.
Anyone find one of these mystical creatures?
Edit: Would a USB wireless adapter work decently, or will they bottleneck the speeds I'm trying to get going wireless N over 5Ghz?
