cold_steel
- Jun 27, 2004
Hey guys,
Specs: Gigabyte P67A-UD5-B3, 2600K @ 4.2GHz, 8 GB PC3 1600
I've been using an EVGA GTX570 for quite some time and I just stepped up to the Galaxy GTX780 HOF card. After I got the new card in I downloaded GPU-Z to check out the new shiny specs, and I noticed it is only running at 8X when this board supports 16X. I tried stressing the card with the GPU-Z load option and also with rthdribl but it stays at 8X.
I hadn't looked at anything with GPU-Z in ages, so I popped my GTX570 back in- its also reporting 8X.
The only other PCI-E device I'm using is an ASUS Xonar Xense in the bottom 4X slot, which shouldn't be sharing with the 16X slot. I did try removing it and testing again, still 8X.
I did just flash my BIOS to the latest version just before doing all of this, and I did not look to see what the link speed was before doing that. I've looked all over the BIOS and I don't see any kind of speed setting.
Please spare me the "8X isn't saturated" comments, I'm aware. I'm just trying to figure out why this 16x slot is not running 16x. Is it possible I'm getting ratty data from GPU-Z and CPU-Z? Or am I missing a setting somewhere?
