PCI-E 1 or 2 for 9800GX2?
Gutspiller
Is PCI-E 2.0 important for getting the most from a 9800GX2 system? If I'm buying a new mobo, am I going to want to make sure it has PCI-E 2 instead of 1?
No. Even the 9800GX2 does not fill the bandwidth of one PCI-e 1.0 16x slot. That's not to say no card you might want someday to upgrade to won't, but you'll be fine with either for now. I am not sure if 8x lanes would slow you down, if you're considering quad SLI, because some SLI designs reduced the speed of the PCI-e slots when running in SLI mode.
Not sure if you are the same person that posted almost the same question on another forum I frequent, but just in case not, then I'll share this link that was posted for this same question...
http://www.tomshardware.com/reviews/pci-express-2-0,1915.html
It shows some performance drop in PCI-E 2.0 mode at x4 speed, which is equal to x8 in PCI-E 1.x mode. So if you have cheap SLI board and you oddly spend $1,000+ on two 9800GX2 cards, you may not get the absolute best bang you could with a real full dual x16 slot board.
However with just one 9800GX2 and a single PCI-E 1.x x16 slot, you are fine as Fiery said. :)
