PCI card relay switch. Need help please.
[em]HEAT
Ok, just got this relay switch for my water pump, the instructions on the site I bought it from tells me to connect the 12v cord from the pump to the relay card, but I see no place on the card to do that. Am I missing something? Am I going to have to cut the end of the pump cord off in order to hook it up to the relay card? This is the relay card that I purchased.
http://www.xoxide.com/pcirelay.html
Any and all help will be greatly appreciated. Thanks.
Yeah cut the cord and you should be able to use the screws to clamp down the wires. Red is + and black is ground -
cut the cord, strip the wires back about 5/16" and connect at the top...those 3 screws should be marked B W and Ground :)
They are marked- N G L
Ok, here are a few pics of the stuff that I'm working with.
ok, so you have a 2 wire...inside that insulation cover you should find black& white, just connect as I mentioned earlier ......I have a via 1300 (2-wire) in one system hooked up to a pump relay, works fine.
dont cut the pump cord.
buy an extension cord and cut that.. then plug your pump cord into it.
He wouldn't want to cut his pump cord incase he wants to sell it right? Well he could just sell the pump with the relay card, it would be worth more then anyway.
can you take a pic of the underside of that card? i would like to know if it has the soldering points out in the open like the criticool2 does......
