PCI Card holder
Vlad_13
Do you guys know where I can find something like >this<?
I will WC my X1800XT, those tubes will put some preasure on her. So over time it will be deformated.
I want something that is made of steel and at least 2 screw points.
SharpieFiend said:
How do you get an X1800XT in a PC that uses ISA cards?
Blah.....you know what I mean, its just a picture...how old r u 10?
I'm thinking of MAKING one... I'm having the exact same problem. Some Rubber C moulding glued to an aluminum support... bent into the correct shape. Or something.
Borgschulze said:
Make one from Acrylic, it will be much nicer than metal.. as in, it won't bend.
That would be really easy to make. I think I will.Cuz my 1800xt sags like a gangsta's pants with a 100 rounds the pockets. Thanks for the idea Borgschulze :cool:
