PCI Audigy 2
Tigerblade
Where can I get drivers for this card? soundblaster.com only has updates :(
Any help appreciated
One way is googling it. I believe there are a few people with images of the Audigy CD you can use......If not I can image the cd for you...
Yea i hate how Creative releases driver updates instead of a full install version.
BTW, what is an Athlon64 XP3700+? :p
Its an Athlon64 clocked at 3700 :) well its originally 3400 but watercooled and clocked up ;)
So if u wanna put it another way athlon64 3700+ that better? :cool:
the last time I did a re-install, I found that one of the drivers on the creative page worked without having any of the previous junk installed. This was for an audigy 2 zs though.
Do you need the apps, or just the drivers?
I would download the "update", then use WinRAR to extract it (WinRAR extracts most .EXE's just fine) to a folder. Then go to Device Manager, choose "Update Drivers" and specify the directory you extracted to.
Just because the drivers are an upgrade doesn't mean they won't work fine this way.
they dont work with me i get major glitches when i use those drivers
