PCI and AGP
the_Ultimate
hey guys if PCI and AGP are used to put in video cards then why do u need like 1 AGP and 4 PCI slots??
man you are posting all over the place. agp stands for accelerated graphics port and semi-shares resources with the pci slots (well the first one anyway), and is only used for graphics cards, was made to replace pci i nthe graphics department because of the lacking bandwith. pci is used for many things tho, sound cards, hard drive/raid controllers, firewire/usb expansion cards ethernet cards, wireless....the list goes on. To answer your question - no the four pci slots do NOT add up to the bandwith of an agp slot.
the_Ultimate said:
so u use all four PCI slots for one video card which adds up to the speed of an AGP slot?? :confused:
heh, no.
A videocard usually only takes up one slot, and thats usually the AGP slot. Older videocards used a PCI slot, however more modern cards need more bandwidth and that is why the AGP slot was created. An AGP slot has more bandwidth than a PCI slot.
Now PCI-Express is a completely new slot, that has nothing to do with PCI or AGP. Motherboards that use PCI-Express can have a number of different kinds of PCI-Express slots but usually a long 16x slot and a bunch of 1x slots for things like soundcards. Again, PCI-Express is still a very new tech and the majority of the motherboards you're likely to encounter at this time most likely still use the older configuration of one single AGP slot (where the videocard typicall goes) and a number of PCI slots for things like sound cards, network cards, etc.
I get it now i thought that u could only use the PCI for a a video card lol!
so if i want to get a motherboard i should get the one with an AGP slot or a PCI-E slot?
just curious :p
pci express if you plan on building a new comp all together. you probably wont be able to re-use your cpu. I suggest agp since you apparently are working within a budget and wont be getting the latest and greatest. sli is what makes pci express useful, so buying two graphics cars to use as one is nice, or being able to buy another down the line...
pci and pci-e are different, and pci-x is different yet. pci is old, and pre-dates agp. agp pre-dates pci-e, which is the most current. Get a motherboard with pci-e(xpress) and get a pci-e(xpress) video card. You can't use one card in different types of slots. I know of only one place to buy an old pci grahpics card.
ill just get a PCI-E slot when i am gonna build my own comp (for the first time :D ) in a couple months!
thx for the help!
You seriously need to learn more about comps before building. Go to a local computer store...not compusa or BestBuy. Go to a mom&pop store and ask them to tell you soem stuff ro ask to watch them build one. Most of the time they will let you watch. They will give you hints of stuff like small things that you may not know such as how to put thermal grease on and stuff.
