hey all
Well, I fanally got most of my new build done still have not pulled the trigger on a GXT 680 yet. use'n onboard GPU......
1 coolmaster fan seems to be my only hardware trouble atm(has a tick)..but just got started.
My spec's
i5 Ivy 3570K
GA-Z77x-D3H
8 GB Ram
212 Evo Cpu cooler
seasonic X750
Case source 210 elite.--120mm exhaust -140 mm Horz position on case side
2-120 mm coolmaster front fans..only 1 in use ATM
OK to my my point ....the Esay Tune 6 utility im going to use to do some lite OC says my PCH temp is at 50 c(125F) at idle..It was at 60 c before I put the side panel (w/ the 140mm fan) on... room temps are about 78 F..my Cpu says 30 c and my system is at 35 c.
Is this ok ? ?...I have not started to run any test yet (mem or prime)
Should I be worried ?
My spec's
i5 Ivy 3570K
GA-Z77x-D3H
8 GB Ram
212 Evo Cpu cooler
seasonic X750
