PC4400 / PC3200 for PC2100 mobo?
Erau
I know this has probably been asked a lot before so please excuse me. The search function is disabled unfortunately. I just wanted to know what would happen or if I even can install higher speed memory than what the motherboard is specced at. I'm using the Tyan Thunder K7, currently with 512M PC2100 ECC Kingston DDR (KVR266X72RC25/512). Also, would it be alright to use non-ECC memory for this board that recommends ECC? I read somewhere the BIOS may not post but would that mean the boot up would be halted and the system would be unusable?Right now I use it with ECC disabled all the time anyway.
Thanks for any feedback you may have.
Ecc ram is slower but more stable than non-ecc. DDR ram, like sdram, is backward compatible with the slower speeds. Unless your motherboard is finicky, you should be fine running the faster ram.
Thank you for the reply. That sounds excellent. Yep, I know about the ECC.. I just got ECC initially because I wanted to follw the mobo recommendations. So, I can probably use faster DDR than PC2100, but any problem, that you may know of, using non ECC RAM?
