PC4-800-E Deluxe-Do I have an error?
KillerTomato
Anytime I boot up the computer, after the AI screen, it says this:
Scanning IDE drives..................
No fastract controllers decected. The BIOS is not installed.
What does that mean? Is it a problem? Everything else on this MoBo works fantastic. Thanks for the input :)
the p4c800 has an onboard sata controller, if you dont use the other 2 sata ports ( sata 3 and 4 ) then itll show up as the 'no devices found' or something like that. you can disable it via bios ( 2nd tab, select the one with all the onboard crap, and disable the sata raid thing ) anyway nothign to worry baout... just slows down boot time if you dont have anything there.
