PC3200 to PC4000..OC'ing advantages???
AndoOKC1
What is the advantage if I switch from PC3200 to PC4000 in terms of OC'ing? will i get a higher overclock than that in my sig. thanks!
no, just use a ram divider to slow down the ram if you think it's holding you back
thanks...i have my ram divider at 180mhz (not for sure of the ratio) but DDR clock is at 207mhz. This overclock required 1.60v to achieve 2.760ghz...alos have one more question CfEclipse... will a prime95 UNSTABLE overclock cause things to run slower? I know windows and stuff can handle error but what is the advantage of a prime95 stability? I know that if its unstable in the first 15-30 mintues then you have a problem but what if its stable for like 5 hours then gives up the ghost? Does this somehow hinder performance or is just for creating the "ideal" overclock? thanks!
If prime crashes some people just regard that as an unstable pc. If you can do what you need without your pc crashing then it is stable. There's no speed disadvantage, it just means that your computer might crash.
Personally I would not run the ram below the standard 200mhz speed. So I would get the PC4000.
arent ram dividers a common tool in the OC'ing process? also, isnt AMD less dependent on a 1:1 divider for performance?
thnx
thnx
Yes, and yes, but if I'm going to overclock at all, everything is going to get overclocked. For me with an Intel system its better to run my latencies high but keep my FSB up. For you it may be more beneficial to keep your latencies down but only run your ram at say 180FSB. You'd need to run benchmarks for yourself and make your own decision. Have you tried overvolting your ram to 2.7 or 2.8v?
yes...the ram is at 2.80v and the HT frequency at 4x. I think i've hit the max of my OC. THe highest I can do with a 1:1 ram divider is 2700mhz while with a 180mhz divider i can do 2760mhz. I benchmarked with FarCry and found that I get the same results essentially. Really, I believe that ram is less crucial with AMD as opposed to Intel.
One question...I heard I have to keep something under 1ghz...what is that I need to keep under 1 ghz and does it have something to do with HT frequency. In my current setup I cant use an HT frequency of 5x, only 4x. Why is that?
also, will changing my latencies allow me a greater overclock?
thnx!
thnx!
I can't really help you that much the AMD specific stuff, I only have experience with Intel systems.
Laxing the memory latencies could help you get higher ram speeds.
Yes, you want to keep your HT link under 1GHz. It has no impact on performance whatsoever, as long as it stays under 1000MHz!
To figure out what it’s running at, take your FSB (270MHz for that 2.7GHz overclock) and multiply it by your HT multiplier (in your case 4x). Like so:
270 x 4 = 1080
That’s your problem, your HT link is over 1GHz! If you lower your HT Multi down to 3x you get:
270 x 3 = 810
And that will allow you to hit more than 3GHz before hitting 1000MHz on your HT link again! So lower your HT Multi and your good to go!
my bus is at 230mhz with 12x CPU multi = 2760mhz.
Right now HT is 4x = 920hmz.
my ram is 2.80v at 2.5-3-3-6-1T
vcore is at 1.6v
ram divider = 180mhz
im getting something like .444897873 rounded, expected to be less than 0.4 in Prime95 around the 3-rd to 4th hour.
any suggestions?
im about to bump up the voltage to 2.85v on memory and loosen the timings to 2.5-3-3-10., but still need to prime it.
vcore is at 1.6v
any suggestions?
All things being equal, I currently have that same memory, and it runs great @ 2 3 3 6 1t, 2.75v, @ 242mhz....now its at 2 3 2 5 1t @231mhz. I know its only guaranteed to work @ 200mhz, but it should do 230mhz easily. You may have reached the mb limit on htt....have you tried dropping your cpu multi, and running ram @ 100mhz divider to see how high htt will go?
mewannafastpc said:
what is the problem with running HT over 1ghz?
why won't it work?
Thats just the limit of the hyper transport bus. Some boars will let you go over 1000 by a little bit, as I am currently stable with 347htt x 3 (1041mhz). I actually had htt up to 375 x 3 while trying to find my max.
when i lowered my CPU multi to 5x and my divider to 100mhz, i came up with 340mhz as my ceiling on the HTT. I want to hit 2.8xx and i cant get it solid over 2.760ghz...any ideas?
i dont get it...with my divider at 166mhz as of today...i thought i could go somewhere up near 240mhz on the HTT. However, I get the same results as a 180mhz. THis is extremely frustrating b/c i feel liek im far away from my theoretical abilities .
:rolleyes: pc4000's rated speed is 250. pc3200 = DDR 400 = speed of 200.
well, your temps could be pushing it, or you may need to increase your vcore. Your cpu can't do 10x 340 likely, thats why you lower your multiplier to test your limit. So don't expect it to.
well yes. But he was implying that pc3200 wouldn't run at "the standard 200mhz speed" which it obviously will, and so will pc4000. If you are going to be running at 200mhz then any pc3200 or higher stick will work, so it shouldn't be a determining factor in your purchase. I was just trying to clear up a misleading statement that might influence the OP to waste his or her money.
And you should get much of a performance difference if the ram divider puts the ram at slightly under 200mhz.
so if the memory is slightly under 200mhz, then will it be a negative or positive performance impact?
