I have an old Epox motherboard with the Via KT266A running 1 stick of Mushkin 512MB PC2100 CAS2 "high performance" ram. There are two open slots. I need to get another 6 months out of this PC but the memory is almost running around 80% or greater. I'm running Windows XP and always have 2-4 programs running.
Can anyone recommend what would give me the best bang for the buck - add 512MB, 1GB, etc....?
Also, can I use any brand, timing, and type - or must it be an exact match of what I'm currently using?
Any information would be greatly appreciated!
Thank you,
EXV
Thank you,
EXV
