PC wont turn on
SUp all...
today while i was playin CS.. my pc turned off it self.. and then when i tried to turn it back on the fans came on for less then a sec then went off... so i opened the comp and tried to figure out the problem.. what i found was. If i take the 12 volt power supply cable that come from main fan and connects to the mobo, out the computer turns on. and if i put it back in the comp turns on for less than a sec and then turns off..
The thing is system DOESNT run with that out either but it does turn on.. but the monitor doesnt turn on.. i dont hear the cpu beep at startup.. the screen stays black but the hard drive light remains on..
