PC wont turn on
SUp all...
today while i was playin CS.. my pc turned off it self.. and then when i tried to turn it back on the fans came on for less then a sec then went off... so i opened the comp and tried to figure out the problem.. what i found was. If i take the Black and yellow Four pin wire that come from main fan and connects to the mobo, out the computer turns on. and if i put it back in the comp turns on for less than a sec and then turns off..
without the 4pin cable in my comp wont do anythin.. the process red light remains on forver and the comp doesnt do shit..
so waht is the solution to this?? i have tried resettin everythin but still no luck? plz help
What "Black and yellow Four pin wire that come from main fan and connects to the mobo"
Fans have 3 wires, not 4.
Do you mean the 4 pin "P4" 12V power connector from the Power supply?
Or a 3 pin fan connector?
If it is a Fan connector, you may have a dead fan that when it died it created a short or high power draw through that the MB can't supply. A new fan will fix this. Don't run your computer without a working FAN on the CPU.
If it is the 12V power from the power supply, and the system runs stable without it (I would be suprized) then just leave it unpluged.
==>Lazn
yeah i meant the 12V power supply wire... The thing is system DOESNT run with that out either but it does turn on.. but the monitor doesnt turn on.. i dont hear the cpu beep at startup.. the screen stays black but the hard drive light remains on..
Could be a bad PowerSupply or a bad Motherboard.
Do you have another powersupply to try?
==>Lazn
