PC Won't Turn On
Dario D.
Update: RESOLVED - It was the RAM that wasn't plugged in snugly. Thanks, all.
Hi all. 'Thought maybe someone could help me.
I acquired someone's computer that they were trying to build, and can't figure out why it won't turn on 99% of the time. ONCE it randomly turned on and worked fine, but not before, and not after. Something is wrong.
I've tried 2 power supplies, and switched from using the Video Card to On-Board video with no effect.
Also strange is that if you leave the computer alone for a long time, then come and turn it on, you see the Power Supply light turn on for a split second, then immediately turn off. Sometimes you can hear a little sound when it does this, but this only happens once after a long period of non-use. The second time you press the power button, nothing happens.
Any ideas? I'm thinking maybe it's the mobo, but I have no idea why it would only SOMETIMES work, and not all the time.
Thanks.
If you didn't put it together then I would take it apart and put it together so you know it is done right, if you trust the person knew what they were doing then I would still do it.
Also make sure everything is set up correctly...if there are any dip switches for FSB or something...make sure the correct memory and compatible CPU are installed....make sure PSU is adequate to supply enough power. One other thing...check the power switch or check for a sticking reset switch.
Thanks for the help. I got it figured out... It was the RAM. As soon as I got it plugged in all the way, it fired right up. :)
Thanks again, all. Very helpful. :)
