My pc stopped working last week. I tested the power supply connecting pins 14 and 15 and the power supply turned on ok. I switched the reset switch connector with the power switch connector and still couldn't get it to turn on. I replaced the motherboard and it still won't turn on. I tried removing components and still couldn't get the system to turn on. I'm not sure where that leaves me. Could the power supply still be bad? Is there any way to connect something to the power switch contacts on the motherboard to see if both switches are bad?
