PC Won't Switch On! HELP!!!
datasafe
AOpen AK86-L K8T800 Socket 754 Motherboard
Hi guys
My first post here and I'm seeking help!
My PC has been working fine for months (since new).
It has an Aopen AK86Lmotherboard with an AMD Athlon 64 3200 processor.
I was using my PC this morning and it just switched off! I thought there hd been a power break but no.
I tried switching the PC back on, there was a quick flash of the power LED but that was it - NOTHING.
I removed the side panel and noticed a red LED on the motherboard was illuminated.
I tried to switch the PC on again, the power LED flashed and the CPU fan twitched but that's about it!
I thought it was likely to be a power supply problem so I replaced the power supply with a new one, made off all the connections correctly, connected the mains power lead, the red LED on the motherboard illuminated. I switched on from the front panel switch. Once again, the power LED flashed and the CPU fan twitched, but that was it - the red LED on the motherboard remained lit.
Any ideas guys?
Cheers
John
The AGP slot is also protected by an LED at the end of the slot that will light if you install an unsupported video card using voltages higher than 1.5V.
Thas all I could find, First thing I would do is find a super cheap PCI video card and try it without the agp card, that LED on might, might mind you, be saying your AGP card has malfunctioned. Not quite sure I would try another agp card till I figured out whats going on, trying that AGP card in a crap computer is also an option, hate to recommend stuff like that cause you never know what killed what.
