Atwooooood
- Oct 28, 2009
To start this off, I recently received my 2nd set of replacement RAM (Corsair Dominator 2 x 2gb sticks) and when i installed them, it ran great...up until today.
I first started noticing RAM related errors (services randomly stopping and whatnot) so i proceeded to run Memtest which came back with some errors. I then proceeded to clean out the ram slots with computer duster and cleaned the contacts of the RAM which fixed the RAM errors, but now it won't POST or do anything with 4 gigs of RAM, One stick (2 gigs) will run just fine, but not both.
I've had this problem before and it just happened to start working again by turning the computer off and on numerous times but thats not doing the trick this time. I've tried clearing the CMOS and running everything back at factory defaults which didn't work. I'm going to update my BIOS when i get home but find that hard to believe that that could be the problem considering I have ran 4 gigs several times without any problems.
If anyone can think of a resolution to this problem, by all means your input would be much appreciated. If you need any system specs, they're in the sig.
