PC with special video requirements...
Syphon Filter
Hi Guys,
I need to spec up a PC that is capable of running 4 monitors at decent resolutions...1280x768 at least if not 1600xwhatever...
The monitors need to be able to display different images on each without any application bars etc visible. Just fullscreen images.
I also need to be able to run videos across the monitors. I would to have the option to display the same video across all 4 screens or have them setup like a video wall/strip so that the video spans across the screens, so that if for example you had a video of a shark swimming, it would appear to swim from one screen to the next sort of thing...
Does anyone know the kind of hardware that I would need to achieve this? This is not for me personally it is for a client, so I am planning on ordering a good spec Dell machine for them and then a seperate graphics card that I can sling in to take care of the imaging/video requirements.
Any help/advice would be greatly appreciated.
You may look at Mac's. A tower Mac (either the older G5 PowerMac or the newer Intel MacPro) can fit several video cars inside. One card would easily be able to handle two 1900x1600 so two cards would handle 4 screens total, and with the better video cards, you could even run 4 30" monitors.
Ok cool. I hadnt thought of using Macs. I will look into that but I am not very Mac literate (I can manage though and I learn pretty quick).
Does anyone have any PC based solutions?
I was thinking the matrox quad head card? The machine is not for gaming so it wouldnt need to do stuff like that.
If the person is going to do a litte gaming as well, you can get a pair of PCIe SLI cards, and put them in non-sli mode so you can utilize all 4 ports of the cards to output to each monitor. That would ensure the graphics cards could still play the latest games if they still wanted to.. I'd just throw in some 7600's or 7900's. That would set them back around $300 to $400.
If you wanted a little better solution specifically made for mulitple monitors, I'd look at the Quadro/FireMV cards with that 60 pin connector that looks like DVI but isn't. It has a special y-splitter it comes with, and it can output quad-monitors on one card. (NVIDIA Quadro NVS 400 PCI, or ATI FireMV 2400 PCI for example) It only takes up one PCI slot. I don't know about gaming performance, but its safe to say, probably not good. They are more geared toward image quality for multiple monitors.
For software there is quite a bit out there. I was looking at the Zenview Manager. It has support for up to 18 monitors or something and is kept up to date with tech support and patches. Check out all their multi-monitor setups and software here to get some ideas of what you can do with it. http://www.digitaltigers.com/products.shtml
But, you also might run into some slight problems. One problem I've ran into with multiple monitors is spanning video across all of them properly. Sometimes if you do it, it will only work on the first screen, and the rest will be black because the card doesn't support video on more than one output. That is something you'll have to check into. Another thing is to make it look good, the video will have to be HD quality, or in the proper resolution to be that wide. At the Detroit North American International Auto Show, they had a bunch of 5ft tall x 50ft long OLED monitors with video wrapping completely around you. I have no idea how they did it, but it was amazing. I don't know if they had special formatted video at a wide wide resolution or what.
edit: Also check out UltraMon multimonitor software. :)
Bargin mate, that is the kind of info I was after. I was thinking about using two SLI cards in non-SLI mode. I know about the video issue from my own personal experience...its a total pain.
What about displaying different videos on the monitors?
I think the new nvidia cards support the same video spanned across multiple monitors now. I was looking at some multi monitor websites, and it shows videos going on both monitors. To get the same video in a super-widescreen format across all 3 monitors, you would have to use the nvidia "spanning" mode in the multi-monitor setup in control panel. Then, you could just set the windows media player or whatever to "fit video to player on resize", then hit alt+enter to make it full screen across all monitors. Just double check and make sure with someone who has done it before to be positive before you go order anything. You want something working for you on the first try that will give your client no trouble.
different videos on each monitor works fine as long as the player you are using allows for mulitple instances. I use Zoom Player and it allows for this.
I did a triple setup once as a test since I had 3 monitors and 2 cards in my main machine at the time. All the videos played fine, the shot below was a test of playing the same clip on 8 machines (11 instances of the video served from one machine) to see how it would play.
Perfect my friend. Thank you.
We tried this on my friends setup and when you went to full screen, the video was in the center of both screens, since the montiros are a lot wider than the 4x3 and 16x9 sizes.
you could zoom in on a 16x9 source to fill the screen though, but you end up cutting off the top and bottom of the picture..
ah, k. Thanks for clarifying. If you could get the original 4:3 or 16:9 video to span across all 3 monitors though with distortion stretching, it would be really thinned out, even more-so than when you play a normal 4:3 encoded DVD onto a widecreen HDTV.
