PC Upgrade
cryp
Hello,
I'm thinking of upgrading my PC a bit.
Here's my current setup:
CPU: E6600 @ 2.4GHz
MOB: Intel DP965LT
RAM: 2x1GB DDR2 667MHz
GPU: Leadtek 7600GT 256MB
HDD: Western Digital 250GB
PSU: Topower TOP650P5 650W (2 +12V rails, one has 20A and the other 18A)
MON: BenQ LCD 17" @ 1280x1024
CASE: Simple with 2 fans and 1 vent on the right side panel
I'll upgarade this: CPU, GPU, Case + fans.
Here's what I'm thinking of:
CPU: Q6600
GPU: 8800GTS 512MB (G92)
Case: CoolerMaster RC-690 + 3 120mm exta fans
I'm not getting a case for overclock, I just want to make sure that the 8800GTS wouldn't get hot, because I have a simple case. As well as lower the temperature of the other components because the summer here is hot.
If I bring the Q6600 do I need to upgrade my mobo? (I'm not overclocking it).
I saw in Intels website that in order for my mobo to support the Q6600, I need to update the BIOS, If I update the BIOS, is there any risk that somthing would go wrong?
Also, I might be able to exchange my E6600 with the Q6600 and pay the difference.
I wouldnt get it if I cant exchange it or if the difference is high, in other words i'm not going to pay the whole price, i'm just thinking that if i exchange the E6600, it would be worth it.
Lastly, is my PSU enough?
Any opinions?
Thx
I would say that you should just upgrade the video card for now. The rest of your current setup isn't that bad. Even just a single intake fan, or any passive intake vents should be enough for an 8800GTS since it evacuates its hot air from the case. Look into Rivatuner for increasing the fan speed to help boost its cooling ability.
What do you do with your system that needs a quadcore? If nothing, then don't bother, as you won't notice any performance difference.
