pc-tv
dyno114104
hi i own a rca 27 inch tru-flat tv with s-video, i tried hooking my computer up through the s video inputs, it loaded fine and looked great in dos, but as soon as i got into windows it looked like crap, i messed with the resolution that did nothing, it is like a blurryness, like lines going through it wierd, but when i play a movie on the comp connected to the tv, i find that it works good, how can i fix this thanks
In my opinion I think the problem is that your tv just doesn't have the resolution to match one of the standard resolutions of a PC.
Someone correct me here but I believe I am correct.
What is the exact model of your tv? If you were talking about say for instance....a westinghouse 37 inch High Definition tv...then you would be able to use it as a monitor because of its high native resolution.
I just don't think your rca tv has a high enough resolution.....sorry.
seconded
