Pc turning on for a split second then turning off
whiteoral
So i built my pc yesterday and got the drivers and everything and it was working 100%. I left it on overnight to download some music. When I woke up in the middle of the night it was turned off, so i tried to turn it back on but it shut off again after a second, so I just went back to sleep. In the morning, it was continually shutting on and off. On for a about half a second, then off for about 5 seconds, repeat, until I unplug the cable. Every fan inside goes on for that split second.
8800gt
520hx
e8400
4gb gskill
antec 900
xigmatek cpu cooler
320gb maxtor
ep35 ds3l
Any ideas?
Try running the motherboard outside of the case. If it works, then chances are that you may have a short inside the case.
Are you using a surge protector or an UPS to power this machine with?
remove all parts except
CPU / Ram / Vid card
everythig else OUT - see if it is shorted
if it powers up then, add other items in one at a time... could be a bad PSU, that is usually what happens in the case of a under powered system, but you got a decent PSU...
Most likely mobo or PSU problem.
Are you running the latest bios>?
