PC trouble
Fantasyalive
Hey, I am running the system in my in my sig. There are a couple problems going on and not sure if related. First every couple days my PC will turn itself off/become unresponsive during night. It's never happened while someone is playing but it won't respond to anything other then turning off powersupply and/or unplugging from the wall for a few seconds and the the power button will respond and start the PC afterwards. Upon restarting it will never load windows properly the first time, just goes to black screen after the windows logo. I'll hit reset button and on the second load it will give me two options, one to load normaly and the other says something along the lines of delete restore data etc. It will only load poperly if I hit the delete restore data option. After that it runs normaly besides the other issue which is upon loading bios and my hardware management only reconize 3 cores on my processor. Restarting doesn't change this, and no I haven't gone into the bios yet and fiddled around, was going to see what people might suggest first. Windows 7 64 bit is my OS.
Ide start with bios. If it has always only seen 3 cores then thats not the way it should be. Maybe update the bios. Then check the cpu if it still doesn't work properly.
I've had friends who experience that problem from time to time, most notably with laptops. Generally I clear sleep/hibernate data or expand the amount of space that it uses and that fixes the problem for them, but on my system I disabled those functions immediately after installing the OS and have never experienced that. If that BIOS update didn't fix it, try diabling these features and see if that fixes the problem.
On a desktop I usually disable any and all hibernation. Sleep modes seem to produce similar issues, but less often. To save drive space (there will be a file held, that is the FULL size of memory in PC, even if hibernation disabled), and disable it just kill it in the brutal command line fashion.
Pull up a command prompt, and type the following:
powercfg.exe -h off
Saved me 16GB of disk space, and eliminated a lot of my woes.
I also typically go into device manager and disable ethernet power saving features.
mine has been doing this recently, maybe once a week.. (I have a PII 945)
on mine it started after I installed a sound blaster xfi, so I attributed it to their infamously shitty drivers.. maybe I was wrong.
I did a new powersupply at the same time, but it was a decent unit, a seasonic x750.. not sure if it could be a powersupply issue, since power has to be reset at the supply to get it started again
Ok, I'll take a look at the PC sleep mode.
Yea, I thought it might be a PSU issue as well and I have a decent PSU too, a Corsair which I believe was origionaly a Seasonic rebranded. I did also add couple months ago a Corsair 1500 headset with its accompanied drivers. Would be interesting if it was somehow affecting it but don't think that's likely.
Thanks for the suggestions.
-edit so did it again last night. Just used that prompt to kill hibernation, and turned off power saving for the ethernet. Will see if that works.
