PC to TV problem
Boozer
hi, i got a problem which id rather ask about before i try to fix it myself. i dont know if it will hurt the tv so thats why id rather ask. so heres my problem. i got a sony HDTV, and i tried to hook my computer up to it last night to watch some movies i have on my comp, and i was bored n wanted to see what it looked like. my tv has a DVI port in the back so i was like sweet! i hooked everything up. booted my computer the bios looked fine. i could see everything nothing looked chopped off. but as soon as it went into windows the screen was like cropped. i could only see half the start bar and not the full desktop. and everything was big because of the low resolution *600x480? i think* i went into display properties to fix it but it wont let me change the resolution. and im not sure that would have fixed it. what do i need to do to fix it? its a 47" widescreen. thank you for your help n time
Find out what the native resolution of the tv is first.
Then download Powerstrip and make the custom res.
hmmm i cant find the manuals n stuff that came with the tv. but i do know from websites is this...
oh yeah its 46 inch not 47 my bad
Display Format 1080i (HDTV), 720p (HDTV), 480p (EDTV), 480i (SDTV)
Digital TV Standard HDTV - HDTV receiver is integrated.
Built-in Tuner NTSC
Aspect Ratio 16:9
Screen Size 46 inch
Aspect Ratio 16:9
Projector Technology CRT
thats all i know. i cant find anything on native resolution
