I have a rather strange problem with my PC, in the last few days it has suddenly got very very very hot.
Nothing has changed hardware wise except for the exhaust fan which is now 22cfm as opposed to the horrible 25cfm LCD Coolermaster one that came with.
All fans are working, none are dusty. None are obstructed.
My CPU max has gone from 55 under prime95 to >=65 playing X2 before shutting down at 70 degrees and while I don't know the GPU temp I can't touch the back of the card as it's too hot. The PSU is also very hot to touch and the rest of the case is getting warm from all the heat inside it.
Anyone have any idea what might be going on
Specs
P4 3.0@3525 - Default Voltage
2*512MB Corsair PC3500 CAS 2 Ram @ 2.9v
SLK900u with 92mm Papst fan
Abit IC7-Max3
Asus 9800XT @ 440/800
Soundblaster Audigy XS Professional
Zalman 430W PSU
2*160GB WD Drives
1 Sony DVD/R
Coolermaster Black Widow case.
All hooked up to a UPS so power should be conditioned.
Specs
Abit IC7-Max3
Zalman 430W PSU
2*160GB WD Drives
1 Sony DVD/R
