raygan_gamer2
- Apr 28, 2016
Win7Pro 32-bit/ ABIT IP35 Pro v1.1 BIOS v.16beta09/ Intel C2D E8400 Batch Q748A223 /Xigmatek HDT-RS1283/ 4GB Corsair CM2X2048-6400C5DHX 5-5-5-18 1.80V ver4.1/ CORSAIR 850AX/ CM Stacker 830SE/ ZALMAN ZM-F3RL 120mm Red LED/120mm Yate Loon D12SL-12 Red LED/ Creative Labs Fatal1ty ProGamer/ MSI R7870/ Dell UltraSharp 2407FPW-HC...
The CPU fan is spinning, the case fans turns and stops...try by itself then fails...I'm try to remove the rest of the case fans (4) and see if this is a power supply issue. Then try resetting the RAMs...not sure where else to check.
Thanks for your help
