pc spec with warter cooling
skinneyb
hi hope some one can help have
my question is
i am after some ideas for a new build as i do not have a clue i am after the following
1) budget of 1000 1100
2) must be water cooled cpu ram and vga if budget will allow you may ask why answer just something i want to have a go at pc will not be used for overclocking or hardcore gaming
3) everything must be from overclockers blue coolant please for water cooled system
4) i already have mouse keyboard dvd drive and a monitor
all i want is the best full water cooled pc i can get for the budget so shopping list must contain absolutely everything i will need so once i order it can build from start to finish with out having to order any thing else
no this is a big ask for someone one to take the time to do so thanks in advance
What is the main purpose of the PC?
They don't have a very good selection for water cooling products.
it will be for genarul pc use and some gaming but not a lot just want a good pc with a warter cool system as i want to have a go at one
i completely understand doing something 'for the fun of it' or as a hobby or to learn, but what you are asking doesnt make sense to me. i just dont understand why you would buy a Ferrari to drive into town to go to church once a week; while living off a fixed income. water cooled RAM is unnecessary even for most enthusiasts and hardcore gamers, and will take about 1/10th of your budget by itself. it looks cool though................
have you done any homework yourself or are you leaving it complely up to some stranger on the internet? you are severly limiting yourself by choosing only that website.
BTW his budget is around $1,600 USD.
i wish i had 1600 us id build something good lol it wouldnt be expensive to do watercooling, i just bought 2 240 rads a pump and res and a apogee gt waterblok for 80 us
Well, buying used is completely different from buying new. Buying new, you easily spend up to 3 times as much. From the looks of things, this guy wants to buy new. Besides, watercooling graphics cards with fullcover blocks really adds up fast.
Watercooled RAM usually is pointless. To watercool most RAM effectively, you need to remove the stock heatsink.
No overclocking or even hardcore gaming? Utterly pointless for you to watercool. You're much better off using the money you would spend on watercooling on a better processor or SSD's.
