PC shutting completely off randomly.
neophytal
system:
amd athlon 64 3500+
msi motherboard
2x160gb samsung sata raid
ati radeon x1950 (3 months old)
dvdrw drive
dvd drive
mushkin 550watt PSU (3months old)
connected to APC battery backup XPS 900.
background:
a few months ago i had a problem with my system hard locking. it would sometimes just shut off. i tried
everything, from new graphics card, to switching out memory, and etc. it ended up being the power supply.
i replaced the antec 480watt power supply with a mushkin 550watt PSU. the mushkin is very impressive, and looks
to be built incredibly. (for $100 it should be)
now:
the system ran flawlessly for 3 months, and suddenly my monitor was losing signal and "going to sleep" with an
orange light. i then thought it was a graphics card issue, so i replaced it temporarily with a geforce fx 5200
cheapo card just to test it out. i did this at work, and the system ran for 4 hours and did not shut off. i took
it home, and it shut off within 30 minutes on me. i then tried different outlets, and even tried without my
battery backup, and no resolve. my system now just powers itself down randomly. it can be during windows
startup, 30 minutes after having it on, its really random. but it doesnt ever run long. i had noticed 1 of
the 2 case fans had seized up, sho i removed it, but the system has its side off and is getting
enough air it seems.
after 30 minutes of use, the heatsick or power supply, dont feel hot, and are just warm... the last time i turned
my pc on, it shut off during windows startup, so i am doubting that its overheating.
can i get some suggestions? is my power supply bad again?
by the sound of it... yeah, its a power supply problem...
if you have a spare one, plug it in and put it ontop of the case, then connect all the extra stuff other than the mobo and video card on it (i.e. the hard drives/cddrives/whatever)
and see how your computer runs, if it starts working perfectly again... it might be your PS straining for power..
if it still screws up, reverse the power supplies so that the extra one runs the mobo/video card and see if it works.. if that works... then its still the power supply
however, if both of those dont work... its not the power supply, in which case i'd blame the motherboard
takes some time.. but its better than spending time AND money on something that isnt the problem
P.s. make sure its not yer drivers ^^
