pc shooting sparks.
gesicht
i had a memory stick shoot sparks, it fryed one of the chips and killed my motherboard at the same time. right as i turned it on.
you think it worth my time to try and RMA the memory? the motherboard had to of mess up pretty bad to cause a memory chip shoot a spark and burn a line across a memory chip. you think kingston will RMA the stick? i am pretty sure it is not their fault. i blame the motherboard or powersupply.
the motherboard has no visible damage but is dead too. newegg should RMA it no problem.
i am going to replace the powersuppy before i get new hardware.
Kingston has a lifetime warrenty on their memory... so, yeah they will give you some new stuff. :)
I would try and RMA the motherboard too... (it it isn't too old...)
