PC reboots on registry scan
TheGuvnor
Hi guys,
Have posted this problem in another section unsure where 2 post it, but think this is right section :D so sorry 4 other post.
Anyways, The problem is, when I try and do a registry scan, it gets 2 a certain point(about 15 seconds into it) and my PC reboots its self.
Have scanned no problems with spybot, it found a couple of entries and deleted them, but have tried 2 run Reg-Mechanic and various other reg scanners, all with same problem.
Any ideas would great
Perhaps your system is blue screening and rebooting itself. Go to Control Panel > System > Advanced > Settings under "Startup and Recovery" and uncheck "Automatically restart". Click OK, then OK again and do the registry scan again. If a blue screen comes up, post what the Stop error code is. It may be a corrupt registry. Do a "chkdsk c: /f" in Start > Run and push Y to perform check disk on reboot (assuming C: is your OS partition) Hopefully that'll fix any file system errors you have and fix the registry. If not, I'd say backup your data and reinstall.
PAGE_FAULT_IN_NONPAGED_AREA
***STOP:0X00000050 (0XFFFFFFE8,0X00000000,0X80550211,0X00000000)
Thats what the blue screen told me.
Ran chkdisk,no errors found, and problem still here. :confused:
Thx 4 reply btw :D
Specs are;
Win-XP Home
P4 3.6
2gig Ram
x800 pro
The rest is basic stuff really :D
According to this link: Faulty hardware, a buggy system service, antivirus software, and a corrupted NTFS volume can all generate this type of error.
