PC randomly fails to POST
nerr
See specs in signature. Lately, my PC has randomly been failing to post, which is starting to worry me quite a bit because it is happening more and more often as time passes. When it fails to start, my DFI X48 board's LED display says "8.8.", which I can't seem to find anywhere online. Every component seems to go into full load, including the video card, but they won't boot anything. After about five seconds, the PC shuts down, and either the same thing happens again, or it will occasionally start.
I'm a little bit worried that something might be wrong with my $1500 rig... So what might be the possible causes? Any ideas?
Pull the gfx card and all but one stick of memory and see if it will post.
So boot it without a display and only one stick of memory? Could my RAM be bad or something?
Your RAM could be going bad or possibly one of your RAM slots, i.e. the mobo (highly unlikely though). There is a possibility that your CPU is going bad (slightly unlikely). It should fail POST w/ a few beeps (typically 3 short) if you pull out all of the RAM. Also, you could try running a diagnostic test on all of your RAM, like Memtest86.
Yes, its possible. Also, have installed any new S/W or done any driver updates? I once updated a driver on a Firewire card and after that my rig would no longer post. At first I thought it was a H/W problem. I removed all the cards and only one stick on memory and it posted. Eventually I had to roll back the O/S to resolve the problem because I couldn't roll back the driver.
I have a similar problem with my asus P5K. It was memory related, I think my ram is good but if I set the timings lower than the JDEC default (within ram specs) it causes the MOBO to not post, but only when cold. Weird.
Anyway, it could well be either ram on the way out or if you're using certain OC settings it might be having difficulties. Try resetting the CMOS.
Could you share a bit more background? How long have you had this rig? What's you Vcore? Do you have another CPU you could try?
I have not recently installed any new software or done any driver updates. Resetting the CMOS did not fix the problem when I ran into it the first time. It just kept booting all components to full load, but not actually doing anything.
I've had this rig for about a month and a half now. My Vcore is at 1.35V right now, running 3.3 GHz stable. I have no other LGA 775 CPUs that I would be able to put it and try out, unfortunately.
The best thing to do right now is look for non-invasive, cheap fixes before moving to the more invasive and more expensive fixes. I would suggest changing out the BIOS battery. I had a system doing doing the same thing, and it has worked fine since I changed the BIOS battery. The most common type of BIOS battery seems to have the code CR2032; you can get a replacement over at Walmart or any hardware store. Whether changing out the BIOS battery fixes the problem, you should only be out $3-$5.
That's a great idea. I'll try that after I try swapping out RAM sticks and such. I can't take the system down right now because it's in the middle of some work, but once it's done, I will probably try that.
