Ok I will try to make this quick and to the point.
I built a spare PC out of extra parts I had.
It is running on a Asus A7N8X MB with an Athlon XP 2700 + processor.
I have 2 x 512 Corsair Value Select Ram
a Radeon 9800 Pro AIW Video card and an Antec 350W PS.
Problem is when I boot up it Posts fine then when I try to install windows, like the initial blue setup screen, it reboots. Farthest I have made it to is the screen to select the partition for the install.
I ran Memtest86 and even then it would reboot, well not even reboot, it just shuts off. I got it to run long enough to have 1 error show up on the Ram.
I checked Processor temps and they seemed high, at 66 degrees celcius.
I am thinking its the RAM but last time I had bad ram the puter would reboot, not just shut off and it would work at least a little bit (long enough to install windows). I tried a different PS same result.
Any ideas? Unless you too think it is all in bad Ram. Is it possible that that RAM just doesn't gel right with that MB?
Thanks!
Pete
Thanks!
Pete
