PC Problem
robert
When I turn the PC on it boots and i can even here when it loads windows up the music. The screen is just dead. I sent my TFT I had a replacement TFT screen thinking it was that and so I have a new TFT now but still the same problem the screen is just black
and says no signal.
Any advice would be appreciated.
I am using my laptop at the moment.
system specs? did you try another cable? are you sure its plugged into the right ports? did you try another vidcard?
Try removing all of your ram and wipe it(the bits which go into the slots - theyr gold or yellow color) with 40%(90% is better) alchohol solution aka Vodka, if doesn't help do same with your vid.card(just dont put 2 much). If no go, perform a new clean(format hd) windows installation.
Like enginurd said, try a different cable..
And.. not to sound rude here but.. do not use Vodka to clean computer parts. Stick with isopropyl alcohol, and the higher the percentage the better.. not saying that this will solve your problems, but using Vodka will likely make them worse. Vodka, regardless of the "proof" will leave behind residue that you don't want on your parts.
No big deal, just use some tissues that you clean your screen with. No, most likely vodka wont leave any residue and if does you can wipe it afterwards with soft material.
I used vodka to clean one of my old cpus from arctic silver - which won't remove without alchohol.
