My chipset fan has not spun in over a month but PC Probe reports my MB temps at under 100F (usually between 95-100), Is my Northbridge possibly still getting fried? The dead fan casing is hot to the touch...
I keep the room temp quite low where the computer is and haven't done any major computing with it (no major video/imaging or gaming) since my chipset fan passed on...
I talked to Asus tech support and they said to turn her off... the heatsink alone was not enough to keep it cool... and a burnt Northbridge would mean no display anymore - with no other warnings too look for... just a blank screen to look forward to.
Should I be safe if the system stays stable - or should I go ahead and replace the whole motherboard while I am at it...
Should get the new chipset fan in about a week...
