PC powers off itself
dark_light
Im having this strange problem . Some times when i use the computer for long time for 2 or 3 hours the computer powers off. But it doesn't shutdown completely. The led on keyboard and power led keeps on. If i try to restart ,it won't restart. I plug out the power cable for some time and plug it in again. And it only restarts if i turn it on after half an hour.Before that the same thing happens.
Could this be the temperature problem of processor.
Im using intel P4 3.0G, intel 945GNT MOB, 512DDR2 Ram.
what could cause such problem.
Usually I see random shutdowns as an overloaded PSU. However, your comment about needing to wait for 30mins or so before you can urn it on again points to heat issues. Have you cleaned the dust out of the heatsinks and the PSU itself?
One way to check if it is heat related (it is summer for most of us after all) take the side panel off and put a room fan facing in towards the case and see if you can run your machine longer.
ya , the PSU is clean. Infact i've remove the cover of the casing as i suspected it was a heat issue but the problem remains the same. It wasn't giving me much trouble since i uncovered it but recently i got a video card "nvidia 7600GT" and the problem is back,mostly when im playing game.
If this is the heat issue. How can i get rid of it.
Use Air Conditioning :p
Anyway what is your 7600GT pushing temp wise under load? Check ot make sure all the screws on the HSF assembly are tightend. It is always possible the factory didn't mount the heat sink 100% correctly. If you feel comfortable with the process I would just remount the HSF with some AS5 or whatever you got lying around.
Personally I have noticed an increase in throttling and artifacting myself in the last couple weeks. My apt gets hot though, it was 102 yesterday inside my room, when I decided to go to the office just for AC!
Because of the increasing ambient temp I have decided to try to hepl my GPUs by lowering resolution and capping my frame rate to about 85. Both of these options help decrease the load on my GPU and therefore decrease load temps. I also mounted a fan over both my cards to help with the increasingly hot days here in CA.
As another option you could always try and replace the stock HSF with like a Zalman VF900 or somehting similar.
Holy hell man, 102F in your room? You drying meat or something in there?
102 in florida and people die of heat stroke -)
Have you checked the bios option for the wake on features? Make sure its disabled in bios, sometimes it comes enabled and pushing a button the keyboard will turn it on. However, the times ive tried it, is doesnt work as intended...sometimes it will just power itself on unless i unplug the PSU.
