pc power&cooling
kevdog
seems to be a premium $$$, but any input about whether they are worth the $$$? i used to use their power supplies back in the day.
To power what? They're fine supplies, but overkill for many applications people seem inclined to recommend them for. Other manufacturers make cheaper or quieter PSUs that do the job just as well.
I'll never use another power supply other than PCP&C if I can have my way.
From what I have seen they are high quality and rock solid, and if any thing goes wrong they will replace it. I can confirm that last part since I had one of their older 510 Watt ones go bad. Told them what I found in the RMA form, and shortly after shipping in the old one, I got my new one which was even better then the original :D (original didn't have the PCI-E connectors, and they sent a SLi certified one back )
I've been using this TurboCool 510W SLI for a year now with no problems. Hardware configurations I've used on it:
1)
AMD x2 4400+ @ 2.5ghz
Abit A8N-SLI
Abit AN8-32x
2gb HyperX (4x512)
2gb Mushkin (2x1024)
2x 7800GTX SLI
4 HDDs
SB X-Fi platinum
Water cooling with 4 120mm fans
DVD-RW
2)
AMD FX60 @ 2.75ghz
Abit AN8-32x
2x 7950gx2 for quad sli
4 HDDs
SB X-Fi platinum
2x 120mm and 2x 80mm fans
DVD-RW
3)
Same as 2 except:
AMD FX60 @ 2.88ghz
8800GTX
Been using a Silencer 350 that was originally purchased for a file server in my main rig, Pentium D 920, NV6800 x2 HDs and it's a champ.
No probs for well... about two years in different machines
I had been burning through power supplies about every 6 months prior (just bad luck I think) and got sick of gambling with lesser brands.
