Oline61 said:How to solve problem:
1. Get chainsaw
2. Cut PSU to fit
3. Install
4. Enjoy
Spectre said:
NKDietrich said:And yeah thats a bit surprising, given how HUGE the power supply bay is in that case. The PC P&C site says the 1 jiggawatt PSU will "fit most ATX cases".
zenzog said:Well, I think most cases aren't made with anything (HDDs in this case) directly across (or next to) from the PSU. You can always not use the top 2 5.25" bays if the PSU still doesn't fit.![]()
Cript said:You didn't measure your case to check for clearance before you bought it (9 inch depth)? Would be a waste to return it after getting it custom made. I have a Chenbro SR107 that fits my 850 one fine, same physical size.
Marduk said:I did. It should have fit, but that length did not include the extra space taken by the cables.
Cousin Patty said:That case, with everything inside, must weigh like a kajillion pounds.
NKDietrich said:Personally Marduk, what I'd do is hang the PSU partially out of the case. Would take a bit of work to get a decent solid mounting that way, but would leave you more space inside.
J-Mag said:Actually thats a good idea... The PSU in the V series cases is attached to a removable plate that is screwed into the rear panel of the case itself.. You could use stand-offs instead of screws to mount the plate an inch or whatever away from the back of the case, to get some more room.
If it's anything like the 850 SSI, it's more like 3 smaller units all working together.NKDietrich said:Yep that beast is almost twice as long as the 510 Watt. Probably is two 510 watts bolted together inside. Heh
Most ATX cases have the PSU on the top with only the CD drives in front and PCP&C clearly states on their site that it requires a minimum of 20"NKDietrich said:And yeah thats a bit surprising, given how HUGE the power supply bay is in that case. The PC P&C site says the 1 jiggawatt PSU will "fit most ATX cases".
Bullshit.
what fan did it come with?Marduk said:....
EnderW said:Most ATX cases have the PSU on the top with only the CD drives in front and PCP&C clearly states on their site that it requires a minimum of 20"
http://www.pcpowercooling.com/products/viewproduct.php?show=TC1KW
AppaYipYip said:It's ashame you bought that case, it fits nicely in my Gigabyte Aurora case (a better case than the Lian Li IMHO).
Marduk said:But...the Aurora wouldn't hold my hdds...
Also....I think it's the same fan as the 510 Deluxe. I do know it makes less noise and moves less air than the 510 though. I guess my system doesn't put the same load on a 1KW on a 510....go figure![]()
rudedog said:yes, the 850
Why not use the two slots above and below your floppy drive as well as the top two slots in each bay?
Or you can simply leave it like it is.
Spectre said:
