Pinipig523
- Dec 1, 2004
I just bought one for $65. Is this a good deal? I noticed after I bought it that it isn't the DELUXE version. Is there a big difference between these two versions?
pinoy87 said:oops...I accidently posted under pinipig523. We're brothers and I was using his pc.
It's a turbo-cool.
I also searched around google and the differences I found between the deluxe and non deluxe where that the deluxe has 8 amps more on the +3.3v...40 amps vs. 32 amps. This doesn't make any sense though because if there is more amps on the +3.3v there there should be more wattage but both are rated at the same wattage.
