AndrewCharron
- Jun 4, 2006
Hello,
I currently have a home network set up on my D-Link Router. We have 4 PCs wired in, and 2 (+ laptops) on wireless. Now I built another PC and we're 2 floors away. I installed an older D-Link Ethernet card into my PC, which also has an onboard NIC that goes to the router. Since there are no plugs left on the router, and we're too far for a decent wireless connection (~40% in this room), heres my plan:
I already own a crossover cable. I was planning on going from the second PCs onboard NIC to the D-LInk card in my main PC. Then the main PCs onboard nic to the router. I am using a crossover cable rather than a regular cat5e because (AFAIK) thats what is supposed to be used.
Now, when the PC is done installing windows, (2nd PC is XP Pro x64, 1st is XP Pro SP2), I will go on the first PC, properties for Local Connection 1, and set "Allow others to connect through this PC", then set up the second PC via the connection wizard to "Connect through another PC".
Now, I did read through the FAQ and as far as I can tell nothing is relivant to this case (The crossover cable FAQ entry was close, but it didnt specify weither this worked with internet as well).
Will this work? Is there a flaw with my plan? I am going to test myself, but windows is still installing for another 30 minutes.
