PC P&C 610 Watt
That PSU is a good one.
For less though you could get a better one, the Corsair 650TX
http://www.directron.com/cmpsu650tx.html
Few more amps on the 12v rail, and it's rated at 50c not 40c like the on you linked to. Either way you'll get a good PSU, but I'd go the Corsair way.
Either one will be able to power a pretty powerful computer. What are the specs of what you're looking to put in?
have not decided yet but i want to make sure that somone can buy this and have an upgrade path
I have the pcp&cooling 610 and its a power plant...im extremely pleased with it and its very quiet with my system..IMO you cant beat pcp&c power supplies....their tech support is great..I can call up and talk to a live body about question or concerns i have about power related problems....ive had these power supplies in my last 3 builds for myself and as far as im concerned i wouldnt go to any other brand....If i had to make a 2nd choise it would be corsair tho....i havent used one yet but user reviews are great also..
another thing that amazes me is if i hook up a dvom and load the system the rails never drop..their rock solid....
I have the PC P&C 610 as well and it has been excellent. It may be rated for 610, but the test sheet that was in the box with mine said on full strain mine put out 745w. :eek:
You can't go wrong with PC P&C's products.
thank you all for the replies, i already knew that I wanted it, and you just confirmed it... you made my day, thanks :)
