PC not showing video...
rayman2k2
Okay, in the PC in my sig with the AthlonXP 2400+, it recently has stopped displaying video through the onboard. I then put in a video card (which I knew worked) and still go no video.
I tried a different monitor (and confirmed my current monitor's VGA port works) and still no dice. Unfortunately, I dont have another mobo or CPU to test my current setup. But this PC was running rock stable for quite some time. It boots, doesnt give me a beep code sequence, and all the fans and HDD spin up. Any ideas?
Sorry for being vague, but I really dont know where to go from here...
No it does not. It has always made a beep the second I press the button even when it works, but that is the only beep that occurs when I take out the RAM.
Look in the mobo manual and see if there is a jumper to disable the onboard video.
The video card you are using to test with may be conflicting with the onboard video.
Try clearing the CMOS RAM too.
Does it beep when you pull out the ram?
__________________
enginurd
#3 Today, 12:20 AM
rayman2k2 [H]ardness Supreme
If you took out the ram and you got no memory beeps, I would think the bios is bad.
