PC, Memtest86+ hangs: what to do?
Nickolai
My PC running Ubuntu 20.04 LTS started hanging in random moments, after I brought it with me on an international plane (it's in a tiny mini-ITX case, so I took it with me as hand luggage and handled with care).
When I boot Memtest86+ from GRUB, it starts but hangs at 1 second mark without showing any error. The red '+' symbol continues flashing perpetually, but the program stops running and doesn't respond to key presses anymore. In Safe Mode the result is unchanged. There are two DDR slots on the motherboard, populated with identical Kingston memory modules. I have tried removing them and installing back, one by one, in all possible combinations (one module, two modules...) to no effect.
I tried fiddling with BIOS, in particular resetting it to optimized defaults (just because I see no option to reset to regular defaults) and back, manually, to no effect.
Changing between the discrete and integrated GPU has no effect. So does disconnecting all the non-essential peripherals.
What is likely the matter? What should I do to fix my PC?
Here's my take: it's probably the motherboard that is broken somehow (socket?) and has to be replaced. Just because the CPU is pretty sturdy and hard to break when it's properly socketed and RAM defect is out of the question by testing. Am I right?
Here's the computer's specs, just in case:
Case: NCASE M1 v5.0
PSU: Corsair 600W 80 Plus Platinum
MB: ASUS H81I-PLUS
CPU: Intel Core i7-4770S
Cooler: Be Quiet! Shadow Rock LP
RAM: 2x8GB Kingston PC3-1333
SSD: Samsung 860 EVO 250GB
VGA: MSI GeForce GTX 1050 Ti GAMING X 4G
Extras: E-MU Tracker Pre USB2.0 soundcard, Logitech C920 webcam, D-Link USB2.0 active hub which I disconnect for testing.
Ubuntu 20.04 LTS with Unity installed.
Nobu
Are you running in single thread mode? It's known to lock up sometimes in multi-threaded tests. Also, check the website to see if others have issues with your chipset/cpu, as these are very low level tests, and sometimes it's just an incompatibility.
Barring those two possible scenarios, the CPU, memory, or power going to them may be unstable and causing issues. Make sure the memory is in a supported configuration (supported by the memory and your cpu/chipset), and your power supply is up to snuff and all connectors are fully plugged and undamaged.
Nickolai
The thing came to my mind: why is my RAM working if it's ECC? Should ECC RAM work at all? Don't remember why I bought ECC specifically; maybe the seller didn't advertise the fact? Definitely the price was good and it worked.
I have originally assembled this PC from the used parts (except for the cooler) and one thing I know is it did work well for well over a year, pretty intensively at times (played through 3xDiablo II Resurrected), casually browsing at others, and it didn't hang. Also, I did run Memtest86+ after installation.
Now it hangs.
For now, I decided to risk it and upgrade the BIOS from version 0707 to 2305 (H81I-PLUS-ASUS-2305.zip). If it ain't broke, don't fix it, I decided originally, but now that it did broke...
The upgrade went smoothly, testing now.
Mega6
What are you doing? This board doesn't support ECC.
2 x U-DIMM, max. 16GB DDR3 1600/1333/1066MHz, non-ECC, unbuffered
memory modules
